Is my car overheating? it's smoking... HELP!!!!
Ok I was driving my car today and my thermostat is broken (in my dash) so it stays on C all the time. Well today I had my heater on all the way and I started smelling a burnt smell. I pulled over and popped the hood and sure nuff, there was smoking coming from my engine, from the left side of the valve cover. Anyways, I drove the car to advanced auto parts and got some oil, the car already had oil in it but I put another quart in it. It was fine for about 2 hours then my thermostat went up to like almost to the middle of C and H and then I started smelling the burnt smell again. I pulled over and checked for oil in the radiator and checked the anti-freeze but everything seemed fine. It smoked alittle more this time. It starts fine and drives fine, it doesn't smoke out of the exhaust (from what I could see through the rear-view) so does anyone know what the problem could be? Thanks! :cool2:
Read the signs "Kemosabe"
If your temp gauge is going up and down then the sending unit is getting a temperture fluxuation. and since the sending unit is at the thermastat housing, I suspect that the thermastat is going bad, you had better change it quick before you blow your "head gasket".
As for the smell well coolant has a nuaseous sweet order
Burning oil can't be mistaken I know that you've smelled burning oil before.
Check the oil filter base unit seal this will cause oil to leak onto the exhuast pipe.
Hope this helps. LOL
NSWST8 :cheers:
