choke opener problem (again)
I repaired my choke opener by using and old inner tube and glue, I checked the vacuum before Installing it and all was Fine. Then I checked the Internal vacuum coming from the carb this was good....put it all together and eh presto!!!!....... nothing happened :gun: :gun: .
So I checked the cranking leak solenoid hose # 26 connects this to the choke opener found this was holding the vacuum instead of leaking it. What I would like to know is would this prevent the choke opener from working, I tried disconnecting the hose #26 so it would leak into the air but this didn't work either.
Or does any body have any other ideas apart from trashing the damn car.
The car is rough at idle until it warms up then its fine.
