Does anyone know how to adjust the camber on our cars without buying a camber kit?
Prelude upper A arms. That is the only way. There is absolutely no way to adjust camber without swapping parts unless someone superheats your suspension and bends it into place. I do not suggest this.
NAAAAAA they bend easy without heat, just have a couple cars run into your rim and it'll bend! LOL acctually i was suprised at how easily they pressed back out once they get bent, but i dont reccomend this either, found out the hard way. i got camber kits from NAPA for 30 some bucks, thats not too bad, and can even get some caster in the tire too if you want.
damn,
just $30 ?? is that for the fronts ? i assume it was 30 each right.
That sounds really cheap? If that is for each side then that would sound about right.
let me know!!!
it's $30 for the pair, at least that's what I payed.
That's a damn good deal. I only needed one for the front right to correct a defect in camber from when the car was new. I paid $75 for a single Ingall's kit. That one tire FINALLY wears evenly.
I guess they thought it was weird to just order one until I explained that I had now lowered the car, just wanted to correct a camber problem without paying $250 to a frame shop for bending.
CASH24
Where did you go to pay that much for the kit you got????
