3 Geez daytime running light mod
Hi All.
If your like me and like to have daytime running lights but don't like the pop-up headlights on during the day because I think it ruins the look and aerodynamics, switch your corner side lights with your front indicator lights by crossing the wires using quick-connects and about 3 ft of wire. Once you've wired it then change your corner side marker bulb with the next size up. You'll have to file the corner socket a little to get the larger bulb in through the lense hole but minor detail and it still seals and locks. I did it and it looks great, is safer and didn't busy up or make front of car tacky as some fog/running light add-ons can sometimes be. Keeps the car looking stock. You just run your park lights so what used to be your orange indicator which is quite bright, is now your orange running lights. You have to change the corner light bulb up so your flasher flashes at normal speed, otherwise it flashes too quick and the brighter bulb is easier to see during the day through that somewhat greyish corner lense. Give it a try. Goodluck, Mike
