I decided to tackle the my problems with the cruise control today. The horn also did not work either. The first thing I did was take everything apart in the steering column and clean and put back together. That did not work still no horns. So I took the bumper off, this sucked because nearly every fastener had to be drilled out. I pulled the horns out and the three out of the four terminals were broken. I went to the junkyard filled my pockets with new nut plates, fasteners and two horns. Installed the new horns still no noise. I noticed that the white/yellow wire had the wire showing thru the insulation. I replaced both of theses wires with brand spanking new wire. Viola the horns finally sounded. First time since I owned the car. I thought this would solve the cruise issue.
When I road tested the cruise light would come on after I depressed the SET button, however it would quickly turn back off and not engage.
Could it be something with the solenoid?
I got no idea at this point. Anyone else have a similar problem and fix it?
:dunno:
