4G accord MAP sensor follow up
OK,
well, today is very nice day, so i figured why not try it.
i got spare 3g map sensor, cut the plug off and solder it to 4G accord map sensor. the sensor i got came out of 4g coupe.
here are weather conditions for today: 63 deg sunny.
here is what i have done to my car so far: headers, no cat, Dynomax muffler, K&N filter (stock replacement, i still have stock plastic air intake). Accel coil, 4G injectors.
i ran two test, one after another. the results are amazing. it has a lot more power. the bottom end between 2K -3K is very nice and it pulls hard all the way to 6K with ease.
i will have more testing done through out next week. i want to see what my gas mileage will be. i will keep you guys posted.
my final word: DO IT!!!!. it is cheap and it is easy to do.
just get spare 3G map sensor and 4G map sensor. connect the plug from 3G sensor to 4G sensor and connect the vacuum lines. it is that easy.
P.S. because 4G sensor is diff, it won't mount inside the box. so i just mounted on the side of the box by using the screw that holds one corner of that black box.
