Blaupunkt GTA2100 amp for my system?
Well im thinking of buying a Blaupunkt GTA2100 from someone second hand for $100 AUD + some p&h. I plan to use it to run my Pioneer 4" splits to get some better sound out of them. THey are rated at 50wrms and the amp puts out 2x50rms so i guess this should work fine, but just want to make sure. So yeah will it pump okay?
Also are these amps good, is the price good, remember its Australian and not USD.
Cheers.
Specs on Splits:
10cm Packaged 2-way Component System
150 Watts Max. Power Handling, HPF≥450Hz
50 Watts Nominal Rating
Frequency Response 70 - 25,000 Hz.
Efficiency 90dB
Impedance 4 Ohm
Dimensions
Mounting Depth 59mm (1602 Woofer)
Mounting Depth 43mm (1002 Woofer)
1602 Diameter 165mm (155mm frame)
1002 Diameter 130mm (102x102mm frame)
Tweeter 49mm (diam.) x 21mm high
Construction & Materials
HRT Hydro-Resistant Cone Material
13mm PEI (Poly-Ether-Imide) Tweeter
In-Line Passive Crossover (HPF, -12dB/oct.)
Black coated steel frame
Aluminium Short Ring
2-Way Surface Mounting capabilities (tweeter)
Spec on Amp:
2/1 Channel Car Audio Amplifier GTA 2100
Max.Overall power into 4 Ohm 400W (1-channel-mode)
Max. Power into 4 Ohm 2x100/1x400 W
RMS power into 4 Ohm 2x50/1x160 W
Frequency range 10-55.000Hz
Signal to noise ratio >80dB
Adjustable Input Sensitivity 0,1-8V
Stability 2 Ohm
variable low pass filter 100 Hz switchable
Bass Boost 0/9/18 dB switchable
Inputs/Outputs Goldplated
Dimensions (WxHxD) 218 x 57x 250 mm
