what part's can i use off a 90 accord ? will the all the glass fit ?
~ The Map sensor with the wires can be adaptedQuote:
Originally Posted by customandsound
~ The alternator can be adapted (u have to have a efi 3g to use this 4g alternator)
~ The heater and Fan control is adaptable.
~ Mis items like the fuse and relays and light bulbs in the dash and gauges and doors can be used
~ The glass is different and so is the side mirros and window glass.
~ you can use the Injector resistor box and injectors if you want.
