a quick CV joint question
well it looks like a CV joint replacement is in order now, wow everything on my car just seems to be messing up, now lets say i just wanna repalce everything that could really go wrong (both driveshafts) to get rid of the click this is what i would want right?...
Drive Shaft / Axle
For vehicle: 1989 HONDA ACCORD LXI L4 2.0 Liter FI (change)
Cardone 604000
CV Half-Shaft Assembly: Reman.; (Front; Right); (Front; Right; w/A.T.); (Front; Right; w/M.T.)
Lifetime Limited Warranty Find in a store Ships in 1 day
Weight: 19 lbs. $59.99
$45.00 core
Cardone 604006
CV Half-Shaft Assembly: Reman.; Front; Left; w/M.T.
Weight: 18.5 lbs. $76.99
$60.00 core
(also are those good prices? i think i can get em for that in the store and then i wouldnt have to send the core out somewhere)
as always thanks guys
You can find them in the stores
Unless you can get them for less than half online or better its not worth the hassle if one goes out on you. this way you can just take it back to the store you got it from. Especially if plan on keeping it for a while and I would also recommend changing out the shaft seals at the transaxle get the dealer OEM I have had no luck with the after market seals.
Hope this helps
Phil :cheers:
