Car pulls hard to right side
Ok, I know this has been discussed numerous times, but suspension/steering problems are different for each person, plz help me if you can:
I just noticed that the car pulls hard to the right at the speeds 35+. At about 45 if I let go of the wheel the car would go off the street in 3 seconds! I don't feel unusual vibration, it just pulls to the side. When stepping on the brake, the car seems straight. It seems like the steering wheel just turns to the right contantly.
I just replaced the front right caliper (I popped the piston out by accident while inspecting it :uh: ) It still veers off. I will look at the rear brakes this evening. I'll also change the tires around and see if there's change.
But could be PS be malfunctioning that bad? I changed the fluid and belt when I took out the AC...
The suspension: most ball joints are new. I changed and adjusted brakes recently so maybe I did that wrong... I do feel some vibration when I brake. The wheel caps are very hot on all wheels save rear right... What should I look for when inspecting brakes?
Can the wheel bearing go bad this fast? The car seemed fine a few days ago.
The biggest problems is that I've got to go on a trip today. Its a 3 hour drive. Is it safe to drive for this long if I don't solve the problem?
