Oil All over the firewall behind carb
alright i'm just woundering, since i'm going to be selling my car as a parts car not bothering doing anything more to it unless i can fix this one problem...
I had my car towed last week due to my transmission, long story short i took it out for a spin at the shop, thinking the fluid would help since all the other magicly disapeared, well i got 15 ft down the road from the shop and i herd this PPPPPPPPSSSSSSSSSSSST sound and knew something was up cause i looked behind me and i was leakin ALOT of something thinking it was tranny fluid, like i blew a seal or something since i was trying to get it to shift at 7 grand,well little did i kno the oil light came on as soon as i got the car turned right around to the drive way, luckly it was a hill so i just pushed it in N, got to the bottom of the hill @ the shop and jumped out of the car and looked under just to make sure i didn't blow 2 seals but just noticed alot of oil so I poped the hoood and saw Oil ALL over the place, mostly behind the carb, looked around, and thought it was the head gasget but wasn't, then saw the Oil Filter, well that O ring around it was poped up, so i explain to my macanic what happend, he said that looks to be the problem, so we put a new filter on thinking there was two rings there causing the blow out, well there wasn't, just one, so i had to leave and he called me back 20 mins later sayin that he started it up and it blew the O ring again from the oil filter, he said something about a valve but i didn't get all of it,
What could be the problem? I mean its has ALOT of Oil Pressure if its blowing that O-ring off i would Imagine....Could I fix just so i kno it will run again without blowing anything else?....or is it worth just leaving alone since i'm just going to be selling the car as parts since the trans is on its way out......sucks cause i literly just got it back on the road and this happned, TWO HOURS AFTER I GET AN INSPECTION STICKER and now its not worth it:mad:
