I Need some roud about info on the B20 and the B16 series of motors i know i can look em up but i want real numbers not something that is might be someone blowing there own horn :rice: or w/e if you could help me i'd b greatly apericated
GO HERE
and here is YOUR ANSWER
BTW :welcome:
you don't need real numbers... just look at the facts. and what type of setup you're going for...
Do you want less displacement or more?
Do you want a motor that there is a lot of support for or little?
Do you want a something that requires cutom mounts and axles or a near drop in swap?
These magical numbers will be the end result of your effort/time and money.
No one can say for certain that one motor will make more power then the next... it's all preferance on how much you want to work to get your power goals.
Exactly, Both have their issues for sure and neither are an easy choice so you have to figure out what you want and what you can afford. Then worry about finding a B20A or even for that matter the hardware you will need for the B16/B18 if Place Racing did go out of business which would not surprise me at all.
