i have a ractive oil pressure gauge put i cant figure out where i have to run the wire to? i also have engine temp but i figure that one out..can anyone help me?
If you are talking about the signal wire (for an electric gauge), you would need to run it to a compatible oil pressure sensor. The stock sensor is basically just a simple switch that doesn't provide a continuous signal so you would need to install an aftermarket sensor. You can either use an adapter or a t-pipe if you want to use both the stock switch and the aftermarket sensor at once.
R Active is worthless... I had a tach from them and the background lights didn't last long and then the gauge itself started tweaking... and then died, I switched to Autometer and that was that.
