November Voting
THIS THREAD IS FOR VOTING ONLY. If you have any questions/comments, please direct them to the appropriate person.
First up is proof positive that carbs are not inferior.
Mike's89AccordLX
https://www.3geez.com/vbgarage.php?do=getimage&id=75
https://www.3geez.com/vbgarage.php?do=getimage&id=48
https://www.3geez.com/vbgarage.php?do=getimage&id=49
http://www.cardomain.com/id/mikes89accordlx
Performance Modifications:
Weber 32/36 Downdraft Carbuerator Re-jetted to Engine
Dual Remote Custom Intakes with Tenzo R Filters
Functional Hoodscoop
Custom Ram Air Box
Chrome Air Filter Heat Sheild
Removed Vacuum Lines and Black Box
Removed Cruise Control
Removed Canister Purge
Rebuilt Cylinder Head
Pacesetter Header welded over the EGR tubes
Pacesetter Exhaust System with Thrush Turbo Muffler
Test Pipe and Stainless Steel Flex Pipe
Pacesetter Adjustable Short Throw Shifter
Deltacam 272 Grind
Custom Ported Intake Manifold
Removed EGR System and have a Custom EGR Plate Installed
Accel Super Stock Chrome Ignition Coil
Crane 11mm Firewires
NGK Power V Spark Plugs gapped @ .050
Autometer Air/Fuel Gauge
Autometer Vacuum Gauge
Autometer Dual Dash Pod
Autometer Dual A-Pillar Pod
Matrix X Voltage Gauge
Matrix X Water Temperature Gauge
AutoGauge 4" Tach with Shift Light
Cobra Radar Detector
Yokohama Avid T4 Tires
Optima Red Top Battery
Spectra Glass Fuel Filter
Spectra Stainless Steel Fuel Line
Mr. Gasket Dual Throttle Return Spring
EBC Sport Brake Rotors (slotted & dimpled)
EBC Green Stuff Performance Brake Pads
Appearance Mods:
JDM Factory Spoiler
Painted Taillights Candy Apple Red
Custom Clear Corner Lights
Accord Factory Bra
Custom Front Bumper Grille
Procarparts Reverse Glow Gauges
Procarparts Clear Bumper Signals
Procarparts Carbon Fiber Gauge Bezel
Grant Turbo Steering Wheel
Momo Steering Wheel Hub
Ichibahn Alluminum Oil Cap
Ichibahn Alluminum Shift Knob
Ichibahn Alluminum/Carbon Fiber E-Brake Handle
Ichibahn Carbon Fiber Shift Boot
SE-i Factory Armrest with Cupholders
Ventshades
1991 Prelude Si Front Seats
Shaved Emblems
ACCORD Emblem on the dash
Powdercoated Chrome Valvecover
Powdercoated Chrome Custom Intake Manifold
Powdercoated Chrome LX-i Thermostat Housing
Red Wire Loom
Headlight Relays
H4 Headlight Conversion
Xenon bulbs
Carbon fiber look gas door
Uni-wiper w/carbon fiber look wiper blade
Spectra Stainless Steel Hose Sleeves
OBX Chrome Type R Pedals
Accord Type R Seat Belt Pads (Front and Rear Seats)
Mugen Resevoir Tank Covers
Audio & Security:
Avital Security System
Kenwood Excellon HU
Kenwood Excellon 6.5" speakers (4 total)
Kenwood Excellon 2x 12" Subs
Kenwood Excellon 4 channel 650watt amp
Kenwood Excellon 2 channel 1000watt amp
Custom Dual Sub Box
Stinger Platinum Battery Terminals (+/-)
Stinger Speaker Wire
Stinger Spiral 4 channel RCA wires
2 Gauge Amp Kit
Suspension:
Front & Rear Strut Bars
1985 Prelude Si Rims
Soon to be lowered with Tokico Blues with H&R Springs
Next up is our friend from around the globe with a model not available to us here in America, the fabled Aerodeck
Paul Aerodeck86
http://www.pauldesign.ru/honda/photo.../sunrise1s.jpg
http://www.pauldesign.ru/photos/enkei6.jpg
http://www.pauldesign.ru/photos/enkei3.jpg
http://www.pauldesign.ru/photos/enkei5.jpg
if you have not yet seen Paul's site you should definitly check it out.
Performance
Custom Air Intake with Honda S2000 Air Filter
CENTERFORCE Dual Friction Clutch
APEXi REV/SPEED Meter
Handeling
KONI Red Special Adjustable Absorbers
H&R Stage 2 Springs 1.5" drop
CHROME Concept Neeper Syncros R16 Rims
205/45/ZR16 TOYO JDM Tires
Apperance
Carbon Fiber Lightweight Hood hot!
Red Honda Type-R emblems
HELLA Side Markers (uninstalled)
Custom ALUMINIUM Grill Mesh (temporairy uninstalled)
Low Beams: HID Conversion: Philips D2S 35w lamps and HELLA Ballast Systems
Hi Beams: HID Conversion: Hella Micro DE fogs (not installed yet)
DiamondBack Headlight Conversion
Ice
CLARION 13cm Front 200W Speakers
CD-Receiver temporary removed
