Finally got my "CRUISE CONTROL" back
After trouble shooting this for months, thinking it was the cruise control ecu and the actuator.
It turned out to be that the rubber stopper on the clutch pedal that depresses the clutch switch.
Honda couldn't get one in for me until next week so I frabricated one from a flat head bolt and a plastic cover cap.
Boy its good to have the cruise back.
So are you running cruise or what?
Do you have an aftermarket or what?
You gave sure a vaguh response. I do alot of driving and the cruise is so nice to kick in on those long stretches of road.
The rubber stopper broke off.
Originally Posted by Luis 89LXi
which was the problem ?
mine does not work sometimes. someother works pretty good. i just changed switch on dash but not solve my prob. i need to test the swich on steering. its so f'ing tired to drive long trips whit out cruise c.
Luis
The clutch switch was fine. I would check your actuator vacuum. But your going to have to be alittle more specific if you want us to help with your problem. There are alot of components associated with the cruise control.
Good luck
