EGR PIPE fitting in DC Sports Header.
Well, i have a dc sports header D-370-1 if that makes any difference. The thing is the egr pipe doesnt even come close to the fitting on the dc sports header. Is there even a way to fit it on? I tried putting in the EGR pipe first then attempt to slide the header onto the block but the studs prevent me from doing anything.
My options right now
go back stock
somehow get that egr pipe to bend in (almost 2 thumbs distance)
extend the pipe of the Egr pipe to fit it.
Busted blue, If your keeping egr.
Your are going to have to remove the Dizzy and the Thermastat housing at the head.
Pretread the egr pipe to the header and then you can angle the header in. Its going to be alittle tight but you can get it in. Put the egr side on the 2 studs first and then use alittle persistance pry bar to help slide to header over the #4 cylinder studs, since the header is rare and out of production you don't want to risk cross threading the header or the egr pipe. I even bought a new egr pipe $56.00 from majestic because my old pipe threads were pretty trashed, wish I were close to my old you pull a part junkyard.
And I also bought some new longer bolts for the down pipe with nuts to give it some extra holding/clamping. M12 1.25 33mm got them at Autozone $5.00
Good luck
