Drilled vs Slotted vs Drilled&Slotted
So, I'm seriously thinking about getting new rotors, pads, and lines for both the lude and the accord.
I hear some people saying drilled will crack if you don't "break em in" right...
And some say that slotted will wear the hell outta the pads...
So I'm assuming drilled&slotted is just a double helping of trouble...
How badly will pads wear with slotted discs? (Axxis semi-metallic pads)
How likely will drilled discs crack?
Does the zinc plating really protect against rust? For how long?
Anyone seen those black discs? Will the black just wear off after a day of driving (where the pad meets the rotor)? Or is it "blued", that metal chemical treating that's been put on many military rifles and guns.
Break in period I would think would be about 100 miles
If that. The black finish as you were talking of is only a protective coating for the non friction surface of the rotor.
anytime that you have friction between two surfaces any coating will wear away. Very quicking concerning brakes.
The break in as you are talking about is the mating of the pads to the rotors the creates the wear pattern which I would expect would take no more than about 100 miles at the most. :thumbup:
Good luck.
