http://www.carburetion.com/after.htm
the conversion kit this place has says for a manual tranny only ? is there a kit for an automatic anywhere ?
the reason for it being for manual only is because of the TV cable... if you are lucky enough to have your TV cable attached to your accel pedal and not your carb, then you can use this conversion... otherwise, you have to: A, make a custom linkage, or B, crimp the TV cable to the accel cable, and IMO, that's not the best of ideas...
my first choice would be to get the accel cable that has the TV cable integrated... both cables come out the same hole in the firewall, and are hooked together at the accel cable... i'm going DCOE, and i don't think i'll have my manual swap by then, so my luck is good here... if you need pics, i can get some as soon as it's light out again
WEBER CONVERSION WITH AUTO
Click on the link above and read thru it... it explains what you need to do to convert your auto to a weber.
I found a nice site for weber 32/36 carb parts... the Accel pump jet is the dual style instead of single, :D
http://www.pegasusautoracing.com/gro...upID=WEBERDGVP
