Help with 87, A20A2 going through fuel??
I am having a problem with my 87 accord, and after searching this great thread for the past 3 days and trying various things, I am still unable to correct it.
O.K.....here's the deal....87 Accord LX, Auto, A20A2 Motor, 132000kms, 1 owner, awsome shape, runs beautifull, idles nicely, warms up fine except.........eats gas..18 mpg! Yikes! This is what I have done: Plugs, Plug Wires, Cap, Rotor, 2 Fuel Filters, Air filter, PCV Valve, new Thermo and A/F, Stock timmimg, Tire Pressure @ 30 PSI, checked coil (how to on this thread).
After doing all of this I still get 16 -17 MPG. Then I increased the timing and it actual made the MPG a little better by a mile or 2 but nothing to write home about. I also noticed a big difference in power between the stock 15 degrees of timimg and the 17 or 18 I had it at. Much more snap with the advanced timmimg and as I said, the fuel economy was a little better?? Not sure what to try next?? I read that the O2 sensor would not make a difference with the carbed engine? What about the air/fuel mixture? Doesn't seem to run rich as the plugs are a light, tan colour and no noticeable smoke. Doesn't burn a drop of oil either. What about the air jet controller or the EGR valve? I also talked to a Honda mechanic that I know of and he just rebuilt the engine on his own 87 carb accord, the same as mine and he is also getting crummy milage. He said I did all the right things and wasn't sure what to try next?
Whatever help, suggestions or advice I could get would be much appreciated.
Thanks in advance and Merry Christmas to all.
Brent
