Guys,
Due to the many problems I've had with my old carb I've just put in a remanufactured carb since I figured it was just too costly to replace any single items.
The problem I'm getting is that when I'm going to work in early mornings I get a fast idle around 2k. But without even warming up I can tap the gas and the fast idle disengages and it drops to normal idle IMMEDIATELY, which is very different than before.
Is there something wrong here? Cuz before the carb swap the idle will drop to about 1500 when I tap the gas after 5-7 mins of warming up, and then drops to normal idle while I'm driving. I've checked that all hoses are routed correctly and there's no vacuum leak or cracked rock-hard hoses.
Does that sound like something's wrong and what should I check?
Thanks guys. :sadwave:
Byron
