Originally Posted by http://www.naftc.wvu.edu/technical/indepth/CNG/CNG2.html
NOx emission mainly depends on combustion temperature and combustion duration...Time is the second factor in the occurrence of NO. The contribution of NO formation is more significant , if the mixture is burned early . Because the early burned mixture has more time to reach equilibrium. Another appearance of time factor is at different engine speeds. At higher engine speeds contribution of NOx is lower due to the less time required to achieve the engine cycle.
