Brake Line
i replaced my rotors and calipers and i need to no how the washers go on the bolts that hold the brake line into the caliper. my brakes wont pump up becuz i forgot how the washers went. Please help. :uh: are there two washers that go on each and does the one that slides over threads go to the top?
http://www.hondaautomotiveparts.com/...13SE00_J12.gif
I'm assuming that you are talking about the parts labeled as #35. From the looks of it, there is one washer (they are identical) on each side of the brake line fitting. So the installation order would be bolt, washer, fitting, washer. Hope this helps.
yea man thats perfect thanx for that!
be sure to bleed the brakes!! :D
