MEMPHIS SUBS................CHEAP...BRAND NEW
http://cgi6.ebay.com/aw-cgi/eBayISAP...sort=3&rows=25
I prefer the ST124's.....there the studio...one of their best SQ lines.
Only 400 watts max for a 12? My 10's will do twice that for half the price lol.
my alpine cost less than that on ebay.
What brand is yours????
PLUS...its not the wattage that matters...its the dB...higher the better... everytime the wattage is doubled add 3 dB...so for example...lets say you have an 86dB sub sensitivity...at 1 watt you get 86dB
2=89,
4=92,
8=95,
16=98,
32=101,
64=104,
128=107,
256=110,
512=113...
now lets say you have a 93dB sub...
1=93,
2=96,
4=99,
8=102,
16=105,
32=108,
64=111,
128=114,
256=117,
512=120...
so as you can see the higher dB makes for a BETTER sub....so the Memphis may only have 400 watts max...but it will kill an 86dB sub anyday....
not sure what DB actually but I know they are 90 or more.
I think what you meant to say is that the higher dB makes for a LOUDER sub.......louder is not always better man!Quote:
Exactly.....shit could be loud as hell but what about the actual sound squality (SQ). And here are the stats for my subs....you wouldn't guess the brand for a couple months :D
Specifications:
Magnet: 160 oz. Double stacked Ferrite magnets
Frame: Chrome heavy gauge steel
Cone: Reinforced non press Paper
Surround: Oversized double thickness PHAT
Spider: Ultra excursion
Power handling: 400 watts RMS, 800 Watts Program (conservative)
T Yoke: Industrial design hex bolt retained, chromed, extended and vented
Cooling: Double Vented (T Yoke and Motor Side vents)
Voice Coils: 4 Layer Dual 4 Ohm High Temperature Kapton
Voice Coil Diameter: 2.1"
Nominal impedance: 4 ohms / per coil
DC resistance (Re): 3.2 ohms each coil
Frequency range: 20 Hz-1.5 kHz
Fs: 40 Hz
QTS: .9587
QES: 1.0437
QMS: 11.7683
VAS: 26 L
SD: .0346 m
SPL: 85.73
Xmax:11.9 mm
Mounting Depth: 135 mm
Mounting Hole Dia.:250 mm
Net weight: 21lbs
Reported SPL Readings of 145 dB Plus !!!
This woofer is an excellent choice for a very high power, high SPL Paper Cone Competition Subwoofer. It's high tech. industrial engineered design and massive motor structure give this driver the ability to take very large amounts of power hour after hour while delivering clean low distortion very high Sound Pressure Levels. The attention to detail and fantastic looks also make this driver a sure winner in overall installation points. This driver will work best in a 1.0 cu. ft. sealed to 2.1 cu. ft. ported enclosure.
DRIVER
- 10-inch Rigid Non-Press Cone
- 1.5" Multilayer Foam Surround
- Double Damper
- Chrome Bullet Cap
- Extended Pole Piece
POWER HANDLING
- 400 watts RMS
- 800 watts Max
FREQUENCY RESPONSE
- 30 - 2000 Hz
IMPEDENCE
- 2/4/8 Ohms (Can Be Wired To Desired Ohm Value Due To Double Voice Coil)
BASKET
- Triple Chrome plated
- Screw Type terminals
VOICE COIL
- Dual (2) Hi-Temp Kapton
- 4 Ohm + 4 Ohm
MAGNET
- 160 oz Double-Stacked
SENSITIVITY
- 91 dB
Kinda long but oh well :cool:
im just going to guess, is it audiobahn? or some no name brand
aight lets put it this way....if you want an amazing sub for SQ (sound quality) then the memphis Studio Sub is you ticket...they have the hard hitting comp subs if you want to pay $500 per...but the ST124 hits amazingly...and it will hit hard if you want it to...so for anyone who wants memphis and KNOWS how good memphis is...then this post is for them...
87pimpsterdocious...I know exactly what each means...the Memphis ST124 has only 87dB so it makes for amazing sound quality...
Your brand sub is prolly...im gonna guess prolly something like focal, crossfire, or Image.
Like I said, it would take a few months lol.
just tell us. it's not adire is it? jl? pyramid? lol
