My Question Is That I Star My Car An In Less Than 2 Min There Is A Smeel Like Rubber Coming From The Hood A Engine An In The Muffler But Im Not Sure If The Engine Is Burning Oil Or Whats Wrong
?????????? What??????????? Smoke coming from your exhaust?
Lol isnt smoke supose to come out of your exhuast .........Did u change your oil recently u prolly had a couple of drops on your exhuast Downpipe or header and its burning so there for smoke is coming out and smells like shit. So check for leaks of u prolly just drop some kind of grease or oil or something. If u have smoke coming out of your tail pipe.....I wouldnt worry bout it only if it was blue or white. then iwould. lol then u got a big problem....hoped i help man
burning oil doesn't smell like burning rubber
and, for your safety, i'd suggest stop sniffing your tailpipe.
you'll have to get more specific for anyone to be able to help. what color smoke, how much, is the car warm, when did it start (after service? after accident? after you hit a huge rock and broke your cat? etc.)... those sorts of things.
good luck
True. Well i just give him some ideas u know since he didnt explain him self.
my reply was to him, sorry chief... don't think i was correcting you. i know you were just trying to help, but without more information we can't even begin really.
Yeah true no prob man.........A newbie u heard the man.
Maybe oil is burning out the exhaust & leaking on the exhaust, can't tell with all the caps on the beginning of what little words there.
I hope you were able to fix it, but the most common culprit on these cars would be oil leaking from the valve cover onto the exaust manifold. I see a lot of junk ones where there is burned crap all over the exaust. that valve cover gasket loves to leak. also check the o ring on the distributor, if it's leaking bad oil could be getting on the exaust pipe. have you checked your pan gasket? the exaust runs right under it and dripping oil will do that. another good point is the pcv hose on the back upper part of the oil pan. they always leak and will get oil everywhere.
This is what i would assume the problem is too, when i first purchased my 87 Accord, there was some smoke coming from the engine after you drove it around for a few minutes, it wasn't too bad, but if you opened the hood it looked pretty brutal. I took it to a mechanic to get the car safetyed, and any little issues fixed up, and it was sure enough a leak in the valve seals. Cost me about $75 Canadian to get it fixed. not bad at all.Quote:
THANKS FOR THE HELP GUY BUT I ALLREADY FIX THE PROB IT WAS SOMETHING MINOR :cool:
