Maybe a different issue for me
My tach jumps too, but the engine power stays the same...
Most of the time the needle gets stuck at 3500-3700 max, but I can hear it rev higher if I keep flooring. When it's stuck like that, I shift at about 3700.
Then I would be driving around 50-85, and as the engine is stressed the tach would suddenly jump to 5500! But - nothing actually changes, engine is going at the same speed. :rofl: When it becomes unstuck, I would shift at about 5500, which corresponds to the earlier 3700 reading.
So my tach lies, and I don't know the real rpms. Oh, and sometimes she likes to start with insanely large rpms, which drop down after some driving...
On the side note, which should be a different issue (or maybe not), I'm about to resolder/replace my main relay, cause she likes to die in some very inconvinient places. I'll put in a new coil too, and will make sure I get the connections right.... Speaking of which, does anyone know what that small black thingy (relay?) is, the one connected to the stock coil?
Another Q: 87lx has an ECU right? You guys say it's under the driver's seat... how do you get to it again? (I haven't tried yet)
Thanks a bunch
