Need Shop Manual for changing head gasket on a20a1 and a20a4, on paul site there only has the B20 engine, need some info , cause want to swap engine parts from the 87 accord exi(EFI) to the 87 lx(CARB).
Thanks
Thanks
paul has the shop manual on his webpage. http://www.pauldesign.ru/honda/shopmanual.html
and where might this be, could u point me to the exact download, cause all i can find is the B20
that link should take you right to the page. you can download each section in .pdf format. scroll down a tad, you'll see it.
ive got the downloads but where is the head gasket for the a20's only the b20s are in the manual
Go the auto parts store. Buy a Hayne's manual. Look in the table of contents about changing the head gasket.
haynes manual sucks already got one
Originally Posted by acessence
library?
The blue/green chiltons is a good book and can be found around town. The helms will mostlikly have to be ordered its $60.
It's in the engine PDF
or it should be.
I used chiltons to do the head gasket, before paul uploaded the shop manual.
I usually check the shop manual, Hayne's and Chilton's. I've found that Chilton's is too generic sometimes since it covers the Accord and Prelude and such a large number of model years. The Hayne's and shop manual are toss ups. Sometimes the shop manual doesn't explain things, just shows pictures. That's when I turn to the Hayne's.
the Engine section does have the A20 head gasket removal and install instructions.Quote:
which page is it on section ?-? and which download
Page 6-4 is where the directions for removing the cylinder head are. That's what you need. Section 6 is all about the head. If you downloaded the engine section, I'm not sure how you missed it.
yea like stevie said, go to the Engine section of the shop manual that you wanna download, and check pages 6-2 and 6-4. All you gotta do is loosen the timing belt along with the cam gear (mark the location of the belt to the cam gear teeth before you pull them off with a white out or something). then pull the camshaft out if u want, not realy needed. and you can pull the head studs out and off comes the head.
OF course you have to remove the intake manifold and the exhaust manifold in order to pull the head. its a bitch to get them all out, but thats the only way.
You can just remove the downpipe from the header and pull the whole thing with the head/exhaust manifold and intake manifold together, its gonna be heavy, but when u put them back, please take them apart before you put the head back on. this is cause , they are soo heavy you might drop the head or bump the head in places and might get the mating surface scuffed. And its not good.
Steve: get back to work :D
