Resetting ECU codes
Ok I searched and found plenty of info on how to read the codes, but how do I reset the ECU after resolving the issue. Do I just disconnect the battery for a given amount of time, or do I pull a certain fuse like on my Chevy pickup or what??
Thanks,
Gene
In the fusebox under the hood in front of the right front wheel is where you want to go. Pull the ECU and Hazard fuse. Leave them out for 30 seconds or so. Or you can disconnect the battery for 30 seconds.
Cool Thanks man
Now maybe I can get decent gas mileage. PO had never changed O2 sensor :uh: :
