Hi Torque Starter for High Compression A20A3
I have an 89 Honda Accord LXi 4dr with a 86 Prelude 5sp. I just rebuilt my engine with custom built forged rods and 11:1 forged pistons. The problem I am having is my starter strains to turn my engine over. I just replaced the starter and put a 790 CCA battery in in. I need to know what starter I can get that will crank my engine over because I have a fealing this starter is not going to last. I need to know ASAP so please e-mail me at:
[email protected]
Thanks!
Re: Hi Torque Starter for High Compression A20A3
Try and swap out the motor, the motor itself is held on by two very long bolts. Maybe a motor built for a different honda starter will fit... I've always nottice most hondas sound the same when starting. I'm sure B18's and such have been built with high comp before and they have a lot of aftermarket parts for them...
Or find a place that rebuild starters.
There were a couple of starters available for the 3G accord.
What does the label says on yours?
I believe it is a Nippodenso starter but can't be sure. I talked to some starter people and they said to check my timing and to add another ground. My timing if 15BTDC. I just need to know what to do. I am suprised this is a new problem that nobody has run into before.
yah fix your grounds/check wiring, that little nippondenso starter should have enough power to turn over just about anything you can throw at it.
I am going to check my grounds and prob run a few more grounds. Will keep everybody updated!
dont forget the ground from engine to chassis and tranny to chassis, check your battery terminals (thats a biggie)
Upgrade all your wiring to 4awg. Mine cranks faster, and its stock, so it helped
yea sounds like your ground,that is a geared starter,they even make a geared nipondenso for v8s now, it even looks the same. that starter should be able to easily crank that motor.
I checked my grounds and they were all hooked up. I ended up replacing them all with 4 ga wire. After that it cranked a little better. I ran a few more grounds and it does great now! Thanks!
