Engine Turned over but Timing belt didn't.
I was replacing my old water pump, I got the new pump on and I sent it down to the shop because I didn't want to mess with the belts. Anyway, the mechanic says he tried to start it up, and the enging turned over, and he noticed that when he tried to start it the timing belt didn't move. This is bad news. If he did turn the engine over, then the valves are prolly bent and the pistons have giant nicks in them, right? Anyway, you guys are the most experienced people I know about accords, so I ask you... is a car that I could sell for mabey $900 worth doing a whole top end rebuild probably costing $600 and up?
Re: Engine Turned over but Timing belt didn't.
Replace the timing belt and you'll probably be fine. I have seen a belt fail with absolutely no damage to the engine as have many others. This thread will probably turn into another interference or not argument, but for $30 why not try it?
Apparently there have been cases of belts break/slip and no damage occur, and it hasnt been entirely proven its interferance or not (PLEASE FOR FUCK SAKES DONT START THIS ARGUMENT AGAIN OR IM GONNA BE PISSED!!!), so if its happened before with no damage, and people can prove it has happened, try it, its not that hard anyways.
Or maybe your mechanic isnt entirely honest, and hes trying to get money out of you
Why would he be watching the timing belt when its starting anyways? Thats not usually the FIRST place you look when it doesnt fire.
yea but a broken belt has a very distinct sound
Put another timing belt on, line up the timing marks on the crankshaft pulley & camshaft sprocket before installing.
Buy a compression tester (guage). Do a compression test on each cylinder. That will let you know if your valves are bent or not....
Edit- if you want to be on the safe side while moving the crank to correspond with the cam spocket, pull your cam out.
how would he notice if the timing belt was to be spinning if he is sitting inside the car starting it?!?!?!?!
but like mentioned above, just replace the timing belt, it could be torn near the crankshaft and on the cam gear pulley its fine
I just brought it up as a possibility, thats why I hate mechanics, I take it there to get something fixed and they try to tell me something else is broken... How do I know for sure? I dont have a camera on them.
Whats your milage at on your car? Its possible it needed a belt and it was convenient it went while at the shop, but I always work on my own cars.
huh? My car just stalled...had no clue why
I took off the valve cover, and lo and behold! the belt was loose. SO loose that I could take the teeth and move them over a notch. That means that there's almost for sure damage to the valves. I tried to start it:uh: a couple times and once is sounded like it fired right, but then it died. The belt is just fine. Funny thing is there was some fairly new wrench marks on the belt tensioner. I cant prove anything but I think I got flubbed up the pooper by that mechanic. Pisses me off. Any suggestions?
Originally Posted by cke
Uhm, guys.
The car wouldn't start, so he probably had a helper try to crank it while he looked at the engine.
Since he changed out the water pump, the timing belt covers were off.
Is it that hard to figure out?
Also, side note. I didn't take the cover off to put on the WP. I just took off the bolts, took the old one out and put a new one in. It was halfway in the case, and I had to fenagle it around a bit to get it out/in, but I didn't have to take off the case. You can see the timing belt through a little square hole in the side.
I thought that we had the discussion about the 3rd gen engines were NON INTERFEANCE engines. So spinning the engine or a broke timing belt will not affect the valves and pistons.
I think you will be okay, the mechanic was just trying to get more money out of you.
Put a new tensioner on.
Yea it sounds like he's trying to rip you off. If the belt is that loose your timing is completely off. You need to get a new belt and get it back in time.
you guys said something about timing marks? I found the right position on the gear, but what do the marks on the belt look like?
it wont matter on the belt. just make sure your cam and crank are both at TDC, there isnt anything on the belt itself that will indicate timing.
sounds to me like your motor will be fine. :)
(non interference)
If there are new wrench marks on it, its possible that hes fucking you over (like I said before) and if it got there fine and it wasnt loose, tell him to go fuck himself
Well, I just went out and fiddled with it, and found that the belt wasn't loose.:uh: It's snapped. The belt seems fine and then there's a couple frayed corners on the teeth and then snap! There's a break. It's like something siezed and grabbed it. Wierd. Anyhow, It's obvious that even if I dont have to do a valve job, I still need to put on a new belt. How would I get the timing cover off? Do I have to pull the engine?
The haynes books explains this procedure very well, you won't need to pull the engine out just support it from undrneath and remove the drivers side engine mount.
Not trying to argue about it, but the motor is interferance engine. Here is a car someone bought with a timing belt broke. Also, my Chiltons says it is interferance engine.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
Originally Posted by ddude2uc
So is it or isn't it? I guess better put, am I mildly screwed or massivley screwed? Because I think I could put on a new timing belt, but if I have to do a engine pull valve job, I don't think it's worth it.
Yes, the engine is a interferance motor, most Honda motors are. I've seen about 50/50 chance of the valves hitting the piston. So you might be screwed, then again you might not. It depends on each situation. I don't know what else to say, but put a timing belt on & do a compression check to see if your valves are bent.
just replace the belt and see where you are at. we cant see whats going on with your engine, so the best thing you can do right now is put on another timing belt. at that point you will know wether or not your motor is screwed up. :)
How is it after 20 years we still havent had solid proof of it being interferancec or not? Just to go facts straight I should pull my head and get prof myself
https://www.3geez.com/showthread.php?t=4744
Could find some more info. off the net too, but isn't worth my time.. Most honda motors are interfereance engines.
Technically, Honda does say that it's an Interferance engine. However, we (in 19 years of business) have never seen an 84-89 Accord engine bend valves when the timing belt has broken. You need to install a new belt and go from there. I really would stress to ONLY use the Honda belt, part number 14400-PC6-004, which lists at $37.50. Most aftermarket brands are recommended to be replaced after only 60,000 miles, but the Honda unit (and SUN, the OEM) is an extended life belt, and should be replaced every 90,000 miles.
