Lets see your custom gauges!
Like the title says, show out you custom gauges! Be it overlays, completely custom, modified or cluster swap(!!!) lets see em all!
Currently mine is in the process of getting re-done, what we are thinking is small 1mm holes drilled at each 20kmh interval and having a blue LED as a backlight there. New text, thinking the 2004 corvette text, it looks hot link
Gonna try to get the signal lights to be more blue than green, or a bluish green, I just hate the look of the slime green color.
Also thinking of painting the whole back piece like a jet black, a little bit of clear put on it to give it some definition. My roommate is going to do some overlay type designs to use aswell.
Ideally (not sure if this is possible) I'd like to have all the text bright white and have a black light at the top activate to light up the white with a blue backlighting.
Dont really know what else to say, post yours maybe get some ideas too :cool:
Re: Lets see your custom gauges!
lol i just went to pauls site and printed them out and stuck em in :) (dont hav ne pics tho :(
ill like some dim lights and were ever the needle is pointing its bright around there :) that would be great
Where are those overlay sheets? Otherwise ill just make my own, but it would be nice to skip a step. Wheres pauls site?
i think its www.pauldesign.ru, yeah they was overlay sheets
Well I must say that Ian first concept looks really good, im going out to buy the materials today, and hopefully have some progress pics along the way
This was a work in progress, but there is the cluster in my old hatch"
http://www.hostilejava.com/images/IMG_2236.JPG
And here is an older pic of the ones in the SEi:
http://www.hostilejava.com/images/IMG_2299.JPG
Heres a WIP, first trial of the overlays. Using pauldesign as a template
http://memimage.cardomain.net/member...17_58_full.jpg Its a black and white temp (because I have to go buy some ink for the color first) to do some lining up, almost there.
They look decent, I suggest you buy some of the vinyl sticker 8.5x11 sheets for you printer along with that ink. Printing on regular or glossy paper isn't going to cut it for in the car, the first set i did for the hatch from pauls site slowly curled and wrinkled because of the humidity in the car forming and disipating.
Oh, and the needles are going to be painted with some black light reactive paint, there will be a black light where the front lights are, and for "backlighting" on the tach 1,2,3 etc will have a small hole drilled with an LED behind each one. Same with the speedo at 20/40/60 etc. And each point on the fuel/temp.
The signal lights will be blue, the face will be dark black.
Any thoughts?
EDIT: Yeah, im on my way out now to buy supplies, picking up some sticker paper aswell for sure. No worries, will have "completed" pics today hopefully. The colors are awesome on it, you missing half of it now
wow, looks good! i want to make some gauges, but most of all i want to buy some reverse glow ones, but thats after i get some $$$
Im printing on the good paper as I type, ill take a picture of it and post it up (since Id rather not have the real template online right now... maybe when I sell the car or blow it up) it looks amazing to me.
What do you think of the flames?
lol what would we do without pauls gauges
ian had his own template too...
hey hostile did you use pauls template for the sei or are they revers glo gauges??
The SE-i is the standard PCP gauges(not reverse glow).
danget, i want some gauges sooo bad, i barely was able to order my headlights, but i did get them last wed, and they still aint here. i was wonderin the quallity on the pcp gauges, regular or reverse glow, and what do you have to do to install them¿¿¿¿¿
The installation is fairly easy, just pull the cluster out, take the cover off, unscrew the gauges, slip the new gauges around the needles and on and put the screws back in. The toughest one is the temp/gas. After that you just need to find a wire to tap into for the power. I used the power for the upper backlight. Since mine have been installed i have had no problems with them.
Holy shit you guys this looks awesome, its 95% done, just waiting for the caliper enamal I used on the needles to dry.
What I did:
The original "blueish" top cover that would have the lights beaming down ONTO the guages, I cut up, and used that color as my signal lights, looks better.
Painted the needles a neon green (was gonna keep the white, but I wanted something different)
Painted the face a glossy black
Painted the backs of the guages flat black so no light would come through. Put LED's behind the cluster to light up the odometer and I cut small slits in the temp/fuel guage for the LEDS to show through (doesnt make too much difference with the black light, thats why I didnt do anything else to the tach)
And ofcourse a 10" neon black light to light everything up.
For those of you who have taken the cluster apart and know what it looks like, there are those 2 wires screwed onto the back (under the tach I think, or the temp/fuel) for +/-. Well for some reason you cant get a solid 12V off of it when its like that, so I unscrewed the - for that and screwed it into the nearest "Earth" screw hole. Works perfect, I'm gonna get everything back together, and take a picture. I'll get dark ones tonight. Damn, I like
EDIT: And for somethign different, I changed the BRAKE light to yellow (the cover anyways)
yea im having a hard time understanding and visualizing exactly what your talking about so some pics would be nice
Will do tonight, hopefully ian is still up (im still at work)
As mentioned earlier in the post, here's the low res concept of what Fyre's guages were going to look like. I didnt think the colors on the real thing were nealy as good due to printer limitations, but they react better to the blacklight the way they are. The plan back then was to have LED needles too, hence the strange blue glow from them. also included is a sample of my motorcycle's new guages, it's all in japanese.
http://img503.imageshack.us/img503/3...ntsdash6iq.jpg
http://img503.imageshack.us/img503/700/bikedash0bj.jpg
