explanation of 84-87 arms
Hello
well my alignment is shot so is my front suspension it bounces squeeks you name it so next year I am going to do everything right. Now I was reading on the 84-87 prelude controll arms. Could someone please explain how exactly these arms compared to the accord arms act to controll the negative camber associated with lowering you're car Thanks Paul
Re: explanation of 84-87 arms
whats up 10 looks no one nows
Here is a thread on Prelude Control arms. Click on the link in the first post. That is a how to on them.
The prelude control arms have a slot in them to bring out the upper ball joint farther. I have a set, cause I dropped my car 2 1/2" in the front. It basically gives you more camber adjustment without buying a camber kit.
https://www.3geez.com/showthread.php?...e+control+arms
so basically installing these arms following the how to should solve my camber problems in the front I am dropped with eibach sportline springs. Also for the rear alignment basically we have to get a camber kit for the rear??
It should. On the rear, there is a little washer trick I hear you can do. Put a washer or two between the fender well where the upper control arms bolts on to it. There is a thread on here somewhere about it that shows a pic & where it goes. If you want, there are camber kits for the rear too.
I did an alighmnent on my car & didn't see enough camber to mess with it, but to each his own.
so the rear seemed fine just the prelude arms seem to be all I should need???
Yep..Hopefully you can find a set.
