how to fill holes after removing emblems
how to fill holes after removing emblems.
1.after removing emblem clean area around holes down to bare metal
2. take a small center punch and use it in the center of each hole to make a shallow depression around the hole,this is to give the filler something to key too,the small hole in the center is not enough surface area for the filler to attach to. if you don't make a shallow impression aound the hole,the edges of it will keep reapearing.
3. use a good quality filler to fill the holes and a couple of inches around them
4.rough sand this area with 80 grit paper you will still have shallow impressions at this point where the holes were
5. repeat steps 3&4
6. now finish sand with 180 grit paper,if you still have low areas you might have to fill again,but they usually disappear after the second coat of filler.
7. use a good self etching primer on the bare metal to protect it
8.finish sand and paint
Re: how to fill holes after removing emblems
um for some reason this double posted again just noticed it,if someone can fix it thanks!
