The brake light is staying on when the emergency brake is down. What could cause this?
Low brake fluid....
really!? but I just had a flush and fill I'll check in the morning when it's light but could there be and other problem?
when my brake fluid level is low it'll come on even when the hand brake is down. also, as my pads ware, it'll come on. but still because of low fluid level. it could just possibly need to settle or something since you just had it flushed. i'd check the level daily. if it doesnt go away in a few days take it back where it was serviced. that light usually only will stay on if fluid levels are low. good luck.
It might be the sensor in your mastercylinder, but your probally just low on fluid....Make sure they tightened up your brake bleeders......
ok Thanks guys
