Re: distributor timing issue
When you fif the EFI swap, did you change the distributor bracket?
Also, when you adjust the timing, do you unplug the 2 vacuum ports ont he distributor and plus them with a screw or something?
I think I found the solution. I was suspicious of the condition of the governor weights and springs, so I bought another junkyard distributor. Turns out the governor weights and springs were completely worn in my original one, giving me full centrifugal advance at all times. This is what caused it to be way advanced. Rebuilt the junkyard distributor and then tried to set timing... right on target! piece of cake.
Sweeet!
Did you have pre-ignition problems? (engine clink-clank)
There was a little pinging going on in low rpms under high stress but not much beyond that. To be honest with you I think the perfomance felt a little better than it does now with stock timing.
So back to the CO emissions, high CO % means that you're running rich or not burning fuel completely, right? You think the excessive advance could one way or another cause unburnt fuel? Or would that be more along the lines of a bad ignition coil?
