changed me fuel filter today, boy was it dirty
this shit is nasty. you can litterly see the dirt flotaing in the fuel. i am going to change it agan to see if it got any better in a month. i may drain the fuel tank and flush it out. i just ran a full tank with some injector cleaner, i may run some more seeing that i have the new filter on. i cant say that i notice any power changes, but i got a better piece of mind knowing that its running a lil cleaner. the filter i took off was a fram, so i doubt it was original
http://img78.imageshack.us/img78/9164/dirtyfuel4tb.jpg
Re: changed me fuel filter today, boy was it dirty
That's the fuel that was in the filter? Nasty!
yeah, and that only a lil of it, i spilt most of it out getting the filter out so it was a whole lot more dirt in there
is it really that bad? has anyone else changed there filter and gotten this?
i could just see that spilling on your phone lol
yea thats pretty nasty.....
is it pretty straight forward to replace the fuel filter..?
just unbolt container, swap out old with new, replace, and rebolt?
or are there any other technical or more complicated things I should be aware of..? thanx
Well, make sure you have a bucket to catch the fuel that spills out of the lines when you pop the filter out of it. But yeah, its pretty easy.
change out the whole gas tank-I paid $100 for mine off ebay and put it in the hatch,was easy and boy was it nasty inside-and my fuel looked better than that when I took it out so that cant be a good thing
its pretty straight forward, just rember whick hose belongs to what side. it may thake some menovering. remove the lines before you remove the filter from the bracket
That's really dirty !
When I changed mine a few months ago, the fuel remaining in the filter was clear.
The color here is quite frightening... :eek5:
thats some damn dirty petrol. and your injectors liked that stuff?!?!?!....lol
thats a flash fone:P...yeah u dnt wanna spill that dirty gas on ur fone it may not like it oi
Wow, that really makes me want to do mine, just in case it looks like that.
i prob will end up changing the tank. i am getting a walbro 255 and i got some rc injectors, dont want to ruin them
I remember shortly after I got my car at 86k, I had the filter changed, and it was really full of water and gunk. Then a couple of years went by, and I had bought another filter but misplaced it in the mess that is my garage. I kept *meaning* to either locate it, or buy a new one, but one day led into another, etc etc until I had probably put 45,000 miles more on the car. It started running a little bit poorly, then more poorly, until it wouldn't hardly run at all. New filter = everything fine, but again, what a filthy mess in there.
one thing about changing your fuel filter on an EFI car to keep in mind:
you should wait awhile (maybe an hour) after running the car before you change the filter. The reason for this is because fuel injection is a much higher pressure system than carbed. If you pop the fuel line off the filter before giving the circuit a chance to de-pressurize, you'll get a face-full of gasoline (happened to me once....thought I was going to go blind....luckily the person I was helping had a gallon of water handy).
lol, i am glad that you are ok
thanks ;-) I had stopped to help this family in a Dodge Caravan that had quit on them.....was under the van pulling the old filter, and got it full in the face, eyes open. Sucked hardcore.....
That's why there's a pressure releif bolt :D
i think its time that i change my fuel filter
That is nasty. I guess I need to do that to my car too.
Originally Posted by cke
I always pop my gas cap, then the relief bolt on the banjo.
Saves lives!
lmao!
mine was like that, when i ran the old tank. Swapped out the tank from Juan (oldschoolswap) and everything back to normal. My car sputtered like crazy and i thought it was an ignition problem, until i decided to change my junkyard filter to a new one.
wow.....really? I've only changed a few FI fuel filters. I never knew they had a pressure relief bolt. Where is it located?
