someone post about this earlier, (were is it)
can someone give me info on hooking up a tach?
Talk to mike A201
You should have four wires on your tach.
Ground- chassis
Power- ignition go to one of the extra plugs at yuou fuse block under the dash.
Lights/Illumination- once again extra plugs at fuse block
Tach signal- under hood at coil, don't remember which side. Try both and it should work.
ok there is red, green, black, and white wires
can someone tell me which is which and were i should hook them up
:help:
ok....Quote:
red - should be ignition
black - ground
green - park lights
white- tach
I'm not 100% sure about the green and white, they be reversed.
