Distributor Seals on A20A1?
Is there an outer seal and inner O-ring on the 89 Accord LX 2.0 Carb engine's distributor where it goes into the head? It seems there is a large oil leak under the distributor and I want to replace those seals. Anyone have a good diagram or part numbers?
I'm also replacing the valve cover gasket at the same time, and I just got done putting in a new oil pan gasket and crankcase vent hose down on the oil pan a couple hours ago. Hoping this stops all the major leaks, I can live with a few minor ones.
Thanks!
Re: Distributor Seals on A20A1?
if you pull out the distributor, you will find one o-ring. replace it and you will fix the problem.
Sweet, thanks! I can just get one matched up that way I guess. Or is it a special guage material? Sometimes Ive found O-rings can come in real heavy guage and light guage in the same diameter O-ring.
yeah, get a thicker one... there are two different oring thicknesses, sometimes auto parts stores only sell one size and you end up with a leak even with a new o-ring.. .I said ffugit... I went to the hardware store paid a like 10 cents and got a perffect o-ring that was nice a thick.
