battery relocation
hey guys wots up, im thinking for this upcoming weekend im going to relocate my abttery to my boot, i already have a 4ga running from boot to bay for my sub so im planning on using that wire for bay to bat and run a 2nd 4ga to the amp, first up will 4ga be bug enuf and is running it just under the carpet safe?
thanx
jay
Re: battery relocation
Should be fine but fuse the cable for sure or if it rubs it will burn
cool, yeh i got a 120amp fuse on it now
going to do the same but since i have a hatch,I need to get one of the morosso sealed battery boxes,and weld in some steel in the hatch to bolt it down to. going to put a forced air oil cooler where the battery is,also an oil acumulator. where did you get the fuse?will need one of those. I still think it's samer to run the wire in loom under the bottom of the car. less likely to start a fire before the fusr blows.
