i saw these, and i've read that people have gotten b series manifolds to fit on a series and what would i have to do to get an Alphaworks Turbo Manifold fit onto my a series?
ummm exhaust manifolds from b engines dont fit ours, what you see peole putting on are INTAKE manifolds not exhaust :slap:
here this link should help you out a lot CLICK ME :D
I remeber reading that somewhere also...Something about having to cut the outer mounting ears to beable to bolt it up.Quote:
Originally Posted by sinisterfuzzy
no. port spacing is way off. you're better off building one specifically for the a20 motor. :)
The only Exhaust manifold that comes close to the A20 is the:
94-97 _ F22
98-2001 _ F23
Even then the port shape is clocked 90 the wrong way and the outer ports are spaced too far apart. The center ports can be heated and stuck in the vise.
You'll still need an A20 flange. Preferably Mild Steel.
Intake Manifold
B16a
B18c5
Listen to the wise man, sonQuote:
Originally Posted by bobafett
