Re: Solid Sway bar bushings?
justs get some urathane bushings works almost as good. if you want true solid end links then you should use a ball bearing setup so it has flex but no slop.
hmm, i had thought about this too. anyone else think this would be a good idea????
Im thinking of trying it anyways. Itll take like 5mins to do, use 12 washers per side (for front anyways, havent looked much at my rear sway) and see if it makes a difference.
You can try it out, but I think it will make your suspension too stiff and cause wheel hop whenever you hit a bump, not to mention that it may stabilize the car but make it unpredictable. I'm sure that if that was all there was to it that we could buy metal bushings.
However, try it for yourself. Just make sure you test it out on bumpy roads and the like.
might look into hemi joint set up.
this is a set for miata's.........
http://www.good-win-racing.com/miata...ms/GWR-062.jpg
Yeah ill still hang on to the bushings (plus Ive got 2 other cars with bushings on them still) incase it doesnt work out. Ill try it out maybe later today or tomorrow.
