Re: Weird Crap in my Head
oh i thought you heard voices in your head.lol
funny guy....i also took off my valve cover and i remember thinking i need a better cam. what kind of oil do you use?
No weird smells. It's the only thing different about the head that I can think would even possibly lead to me blowing another gasket as soon as I did. It had collected at the right and left sides of the head, right at the seam between the head and the valve cover, in lumps. So I don't think it's actual melted plastic. I'm pretty sure those rings don't fit in that hole anyway.
Its not a lot of carbon buildup is it?
Can't post pics, no camera. Besides, I cleaned it off so I could put the valve cover back on and drive the car.
How would I tell if it was?
Edit- If you used a lot of black RTV silicone on the rubber valve cover gasket. It will squeeze out into the inside of the valve cover.
Rubber & silicone do not mix. It splits the rubber gasket & makes it weak.
Didn't use anything.
This time I used gasket sealer so I don't blow another one though.
