What other wheels fit 3Gs? (list)
Is there a list anywhere of what cars wheel's will fit directly onto the 3G. I saw some really nice wheels on a few Acura Legends, and other unidentified Acuras at the junkyard today, but I didn't know if they would work.
Mostly what I'm looking for is any set of wheels that will be easy to find, at least 14" in diameter, and be at least a little wider than the crappy stock 5.5" width.
Re: What other wheels fit 3Gs? (list)
dude you should get some Acura integra rims or some Civic Si rims. i got a integra fat five rims...they are 15inch and its a 6 inch width...the car handles way better now with some kuhmo 195-55-15 tires. it also looks good on our cars since they are OEM rims...since i did not want to put :rice: rims on my car...well they have: Mesh, fat five, blades, SI rims, they are all 15 inch its not too big and its not too small
Stock 3rd Gen Accord Bolt Pattern is:
4bolt x 100mm - with - 12mm x 1.5 Lugnuts
Cars with same pattern:
OEM wheel size listed
Acura
86-01 Integra 14x6
Audi
79-84 4000 14x6
76-84 4000S 13x5.5
79-84 Coupe 14x6
76-84 Fox 13x5.5
? -87 Quatro/80/90 13x5.5
BMW (mid offset)
84-91 318/325 14x6
79-83 320/323 13x5.5
Chevrolet
75-86 Chevette 13x5
86-89 Nova/Spectrum 13x5.5
Dodge
81-86 Aries 13x5.5
84-85 Caravan 14x6
82-86 Charger 2.2 13x5.5
93-94 Colt 13x5.5
82-84 Daytona 14x6
94-96 Neon 14x5.51
78-85 Rampage 14x6
Ford
91-94 Escort LX/Wagon 13x5.5
91-96 Escort GT 15x6
92-97 Escort LX 14x5
97-? Zx2 15x6
Honda
82-89 Accord 13x5
80-96 Civic 13x5
89-91 Civic EX 14x5
86-91 CRX Si 14x6
80-91 CRX/Prelude 13x5.5
92-97 Del Sol V-Tech 14x6
93-97 Del Sol 13x4.5
01-04 Insight 14x5.5
86-91 Prelude Si 14x6
Isuzu
83-89 I-Mark 13x5
87-89 I-Mark Turbo 14x6
83-92 Impulse 14x6
91-93 Stylus 14x6
Kia
00-02 Rio 14x5.5
94-95 Sephia 13x5
Mazda
90-94 323 9 13x5.5
90-? Miata/MX5 14x6
92-96 MX-3 14x6
92-96 MX-3 GS 15x6
90-01 Protege 13x5.5
Mercury
94-? Aspire 13x4.5
91-96 Topaz 13x5
91-96 Tracer 14x5
Mitsubishi
93-96 Mirage 13x4.5
94-97 Mirage 14x5.5
97-? Mirage Coupe 14x5.5
Plymouth
79-90 Horizon/Omni 13x5
81-85 Reliant 13x5
81-85 Voyager 13x5.5
Pontiac
88-93 LeMans 13x5.5
Saturn
91-? S Series 14x6
Suzuki
95-97 Esteem 13x5.5
Toyota
86-91 Celica 13x5.5
88-96 Corolla 13x5
88-97 Corolla 14x5.5
00-03 Echo 13x5
85-89 MR-2 14x6
00-02 MR-2 Spyder 15x6
92-96 Paseo 14x5.5
01-03 Prius 14x5.5
83-97 Tercel 13x4.5
Volkswagen
89-92 Corrado 15x6
85-98 Golf 14x6
81-98 Jetta 14x6
90-97 Passat 14x6
82-89 Quantum 14x6
81-88 Scirocco 16v 14x6
List Compiled from:
http://www.discountedwheelwarehouse...._Reference.cfm
Check out what they look like at this page:
http://www.wheelcollision.com/cta.htm
The only remaining concerns would be offset and the hub center bore.
Dude, this soooo needs to be stickied or added to the FAQ section. Please any admin do this, seriously this would stop lots of dumb questions, lol. Almost every forum I've ever been to has a list of what rims will fit the car in question, so I highly recommend putting this somewhere where it can easily be found.
BTW, thanks a lot Bones, you may be a new member, but this contribution I'm sure is appreciated by many of us ;)
How about it ole mighty lords of geez, if the info in these links is legit., very usefull for possible how to or something , I agree
Done
https://www.3geez.com/forum/showthread.php?t=48188
cool then I wont have to go looking for it when on diff computers, thank you.
hey so i put some 98 or 99 ford escort zx2 wheels and tires on my 89 accord lxi. They bolt on just fine. But i was curious if there was anything else i needed to be sure of. I dont want them to fly off. there is some vibration and before i paid 40 bucks to try and rebalance all the tires i wanted to be sure i wasnt missing something obvious that would cause them not to fit. thanks
bobkar
as long as they bolt on, the bore in the middle is big enough for the hub, and they don't touch anything else you should be good to go.
If the hole in the center of the rim for the hub is bigger than the hub, itll vibrate, or so says a mechanic i worked with. Something to consider.
thanks guys. i will give it a shot balancing them. If it works out i will add it to this post.
ok jsyk the escort wheels do not fit without boring out the center,,, which i do not know how to do. so it looks like i am going a different route
