Vaccum Hard lines
Does anyone know which parts the hard lines are on the Majestic parts site? If you look at the pic of my engine you'll see my hard lines have cancer. I'm sure it's a contributing factor to my idling issues. I would like to replace them all so I can eliminate them as a vaccum leak possibility.
Re: Vaccum Hard lines
the only way to find out is to spray wd-40 or carb cleaner on the lines...and if one leaks the idle would change....i sprayed it and i have no leak....
do yours look like mine? Mine are covered in rust
Try to find some at the JY without rust? I dunno if that would be easy though, considering where you live...
I may have some laying around... it's the canadian version though.
BTW you don't need the hard lines if you have a manual trans... or have an auto strans that doesn't run the tv cable to the rear of the carb.
You'll need a bunch more vacuum lines and a handffull of size adapters and vacuum "T"s etc.
get the thick rubber hoses though. thin walled hoses will collapse if they are too long.
