urethane for upper control arm ??
can anyone point me to a site that sells urethane upper control arm bushings?
for the front suspension i have urethane for the end links, sway bar mounts, and lower control arms,
but I can not find urethane for the upper control arms.
any help ?????
-> 89 accord lx
Re: urethane for upper control arm ??
I never have.
I made steel ones my self where there pressed into the arms and the bolt goes thru them. Simpler that the honda set up and less slop.
woa woa woa woa woa woa whers is that my super man cup nah just kiddin thats from family guy thought ud get a kick out of that but how did u put
and where did u get the urethane lower control arms bushings and tell me how u did the steel omes u made urself im very intrestin ill tell u where to get the upper control arms if u tell me about the lower ones
Uh send me a PM and Ill send you pictures. If im reading your run-on sentance correctly.
I made then out of steel on a lathe 10mm hole for the bolt and .925" or so press fit into the arms. Missed a little on the lengths of the shoulders on the bushings so I had to add 2 washers to get them to space right before there bolted up though the body. Sorry I lost my drawing so I can't remember all the dimensions.
The only thing im interested in the lowers is sperical bearings like you can get for civic arms.
lca bushings from suspension.com-
radius rod, lca, endlinks, bar mounts.....
says front control arm, lowers only though.
http://www.suspension.com/prothane-civic.htm
How much of a difference does it make to switch all your bushings to polyurethane? I'm thinking about dropping about $100 and I am mainly hoping it will make a noticable difference...
http://www.progressauto.com/TPG%20Ca...eb-secured.pdf
this is what I was thinking for the lower arms.
