My first problem with my weber...:thumbdn: I was driving to New Orleans(on the highway doing 70mph) and all of a sudden the car begins to shudder and hesitate. It progressively gets worse so i pull off to the side because i knew i wouldnt make it up the on comming bridge...It cuts off but starts again with pumping the gas rapidly. Also there was a very strange smell comming back from the hood/under the car. Smelled like plastic or something...but anyways I took off the filter and proped the choke plate open, it ran alittle better but still ran like it was missing. I was checking it out again this morning and i notice that when the primary is opening there is an initial squirt, which is good, but after it opens alittle more it sounds like its suckin through a straw at the bottom of a empty cup...and begins to studder:wtf: haha yea i know. I can see the fuel comming from the primary venturi but its not a stream its a irregular spray...It runs fine when you open both barrels tho at WOT, just when the primary is opened slowly it sounds like its missing. Please help me out guys, thanks.
