Originally Posted by roodoo2
Normally you cant find them without buying the whole kit, but you may luck up a Honda dealership.
Search the forum for vacuum leaks, carb base., intake gask....also there are a lot of diaphragm vacuum controls around this carb that you could be hitting with the spray, there is a chance one could be ruptured or taking in the spray. I would use a small tube and see if the spray would come out just a little at a time in that area around the gasket.
You can make a gasket, using the carb base heater thing as a template. Use gasket material from parts store, I have used phone books but they are not thick enough anymore. Last time I used a box that alum foil comes in, to make one.
