86Lxihatch.......
quote:
Originally posted by 86LX-ihatch
That is the exact deck I have in my car. You will not need a kit to put it in your car. There are two screws on the bottom side of your factory radio that will need to be removed and then the factory will slide out. Be careful because they will strip very easy. Just buy a wiring harness for that car so you don't have to cut your factory harness.
wats a wiring harness?
The harness you wire into the aftermarket radio that plugs into your factory radio harness so you don't have to cut any wires.
yea the correct name for it is actually a quick harness
you can find them at any store this days. i know walmart has it.
