How do you get to the right front to replace the bulb? It looks like they built the dang car around this thing!!
right front what? Bumper light? Turnsignal? Headlight?
if you are talking about the corners....pop up the lights and they have 2 screws that you can get with a philips...and then they pull foward.
be sure to use a flashlight...it will make it easier to see the cross on the screw itself :D
If you're talking about the turn signal on the bumper, pop the fog light cover off. Then on your knees you look up and you will see like plaster like material, theres a hole in it, stick a screw driver(philips) in there and unscrew, then just pop it out.
I don't know if this is what you are looking for
http://img354.imageshack.us/img354/9648/1hx7.jpg
