Re: climate control randomly turning off
99.9% of the time is the connections on the boards. you have to take the switches out and resolder them.
Not to jack the thread, but rather than post another thread I have just one question. My climate control is doing something weird too. when I put it on strictly defrost, it still comes out the floor. basically it's like defrost is the same as defrost/heat. Sound like the board connections or more like a cable or vacuum hose or something?
well i would start with board connections. if they are not making any connections it can't send signals to a switch.
Thanks. There is an 89 at the JY I have been robbing of parts. It has really low miles on it but was hit hard in the front and all down the passenger side. none of the lights in my buttons work anymore so I'm betting it's the board. I'm gonna pull the one out of this JY car this weekend and swap them.
alboy86, it does sound like the connections inside the climate control. You can either take it apart and try to resolder the contacts or go to a junkyard and try your luck with another one.
This sounds like it's not even switching when you try to change the functions. It could be a fuse. I'm not sure if it is the same on a 89 but check fuse # 5 (10 amp) in the under the dash fuse box.
:rockon: hmmm sounds like another excuse for me to take the car apart is it hard it take the control box out seems like its all one thing i might just take it a part and resolder it at the same time convert the lights inside to leds two birds with one stone
lol i bet bitesize will be happy...have you seen the pics...they are just HOT...
ya im likeing the setup hes got they re pretty sweet. im gunna go to frys and see what kind of leds they got if not its off to ebay gotta get a soldier gun as well lol then take it out and soldier away might take me a few days to do so i might not have climate control lol but oh well shouldnt be too hard to do
also try radio shack they have a prutty good selection of led's
gunna go tomm and see what they got
that used to happen to me on my old LX once in a while.. i'd press a button the climate control and the lights would go out on it and it would stop responding. turn off the car and come back in 20 mins and it would work again :wtf:
I'll check the fuses but every other function works perfectly. I think either the actual buttons are shot, or the control box is shot. None of the little lights that tell you it's on work anymore either. Probably a combo of both so I'll replace both.
Check the fuse that controls all that. Mine the fuse holder clips were weak and the fuse wouldnt make contact all the time so the controls would go dead. I could wiggle the fuse with my finger and it comeback on.
I think when they go dead they just default to def/heat split it seems.
Also to eliminate the rear def. switch as bad I think you can just unhook it for the time being and the heat controls should still work correctly.
hmm ill try that thanks for all the help guys ill keep ya updated on the leds migt start tomm if i got time
well bitesize has alot..i think they are like 25 cents a LED...he might even ship it on a envolope...so you pay like 37 cents shipped
hmm might have to see about that pretty good deal
i have the pushbutton heater controls just laying around the house and about to be tossed in the trash. if you want, ill just mail it to you for free.
Hmm, i should be replacing both the control box and the push button unit this weekend. I'll keep ya posted.
alright, then its urs, give me your address via pm and ull have it
