Re: Fuel Gauge Acting up!
You probably need a new sending unit or a new dial in the guage cluster?
is it easy to replace/install? and how much would it be at a junk yard
yeah they are in the trunk its going to be on the passanger side...they cant be more than 20 bucks at the junk yard.
ok so where would it be in the shop manual? and where exactly is it located?
i dont have the manual infront of me but it should be under the fuel system part.
Did this happen just once? Are you certain that the tank was full? Fuel nozzles work by pressure, and I've seen a number of occasions where they will trip and stop prematurely. The fix is to back out the nozzle a little bit from all the way in to allow the fuel to flow down into the tank better.
If, on the other hand, you're sure, yeah, check out all that other stuff...lol.
